New Problems in 1.2.1
My client changed her ID and Password. and I started getting errors trying to login to Power Gallery. I changed the ID and PW back in the mySQL table and made sure it matched powergallery.php but I am still getting these messages at the top of:
index.php
<br />
<b>Warning</b>: fopen(../admin_gallery/Connections/installed_gallery.txt) [<a href='Templates/function.fopen'>function.fopen</a>]: failed to open stream: No such file or directory in <b>\\nawinfs03\home\users\web\b1995\rh.lbehar\pg_102\admin_gallery\images\installed.png</b> on line <b>15</b><br />
<br />
<b>Warning</b>: filesize() [<a href='Templates/function.filesize'>function.filesize</a>]: stat failed for ../admin_gallery/Connections/installed_gallery.txt in <b>\\nawinfs03\home\users\web\b1995\rh.lbehar\pg_102\admin_gallery\images\installed.png</b> on line <b>16</b><br />
<br />
<b>Warning</b>: fread(): supplied argument is not a valid stream resource in
<br />
<b>Warning</b>: fwrite(): supplied argument is not a valid stream resource in <b>\\nawinfs03\home\users\web\b1995\rh.lbehar\pg_102\admin_gallery\images\installed.png</b> on line <b>18</b><br />
<br />
<b>Warning</b>: fclose(): supplied argument is not a valid stream resource in <b>\\nawinfs03\home\users\web\b1995\rh.lbehar\pg_102\admin_gallery\images\installed.png</b> on line <b>19</b><br />
<br />
<b>Warning</b>: mysql_free_result(): supplied argument is not a valid MySQL result resource in <b>\\nawinfs03\home\users\web\b1995\rh.lbehar\pg_102\admin_gallery\global.php</b> on line <b>37</b><br />
