INVALID with SagePay
Thread began 12/20/2010 7:15 am by chris382476 | Last modified 12/20/2010 3:18 pm by Jason Byrnes | 885 views | 1 replies |
chris382476
I have integrated with SagePay using their Form method (not server), and the transaction is passing right through their simulator with no problems at all. However, I am getting an INVALID status code even though the transaction is fully stored on SagePay's server with no problem.
The debugging code outputs the following:
SUCCESS:
STATUS CODE: INVALID
ERROR MSG:
Why is this coming back as INVALID if the transaction was successful?
Thanks,
Chris.
impossible to say why it is invalid without more information.
try adding this code to the failure page after the body tag:
<pre><?php var_dump($_SESSION); ></pre>
this may give us some more details on the nature of the issue.
NOTE< The session var dump may contain sensitive information which should be removed before posting here.
