selectedindex can't seem to link to the recordset....
How about someone posts an add to cart properly constructed snippet and then I
ll simply manaually set all my values?
Tech support? Is this possible, can I have a full snippet to configure manually?
I'll post what was constructed via the dialog window even with errors:
Button:
<form name="eCart1_1_ATC_0" method="POST" action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>">
<input type="hidden" name="eCart1_1_ID_Add" value="0" >
<input type="text" name="eCart1_1_Quantity_Add" value="1" size="4" >
<input type="submit" class="eC_FormButton" value="Add to Cart" name="eCart1_1_ATC">
</form>
Add to cart code:
// WA eCart AddToCart
if (isset($_POST["eCart1_1_ATC"]) || isset($_POST["eCart1_1_ATC_x"])) {
$ATC_itemID = $_POST["eCart1_1_ID_Add"];
$ATC_AddIfIn = 0;
$ATC_RedirectAfter = "cart.php";
$ATC_RedirectIfIn = "";
if (isset($totalRows_rs_inventory) && $totalRows_rs_inventory > 0) {
$row_rs_inventory = WAEC_findRecordMySQL($rs_inventory, "", $ATC_itemID);
if ($row_rs_inventory) {
$ATC_itemName = "".$row_rs_inventory['ProductName'] ."";// column binding
$ATC_itemDescription = "".$row_rs_inventory['ProductShortDesc'] ."";// column binding
$ATC_itemThumbnail = "".$row_rs_inventory['ProductThumb'] ."";// column binding
$ATC_itemWeight = floatval("".$row_rs_inventory['ProductWeight'] ."");// column binding
$ATC_itemQuantity = "".$_POST["eCart1_1_Quantity_Add"] ."";// column binding
$ATC_itemPrice = floatval("".$row_rs_inventory['ProductPrice'] ."");// column binding
mysql_data_seek($rs_inventory, 0);
$row_rs_inventory = mysql_fetch_assoc($rs_inventory);
$ATC_itemQuantity = floatval($ATC_itemQuantity);
if (is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0) {
$eCart1->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemThumbnail, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice);
if ($ATC_RedirectAfter != "" && $eCart1->redirStr == "") {
$eCart1->redirStr = $ATC_RedirectAfter;
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
Anyone have a clean set of snippets I can use as a starting point to hand code the required values?
