How to Stop the clean text copied from word option from coming up
Thread began 12/14/2010 6:35 am by hbibizadeh396670 | Last modified 12/14/2010 8:55 am by Jason Byrnes | 1896 views | 5 replies |
hbibizadeh396670
How do I stop the option to clean text copied from word from coming up.
This is causing me a problem because I have created an online publisher. When people use this option the format is destroyed!
after the form is created, click on the HTML Editor element then in the properties inspector, click the edit button.
On the toolbars tab, you can remove the Clean Text Copied from word toolbar button to remove that options.
hbibizadeh396670
Actually, I have already removed the copy from word button in the toolbar.
The problem comes when you right click and past or press control V on the key bord
to be honest, it is not a good idea to copy formated text from word into HTML Editor.
the formatting used by word is not HTML/CSS style formatting. MS Word Formatting will break your web pages layout.
hbibizadeh396670
Ok
Well I fixed this. Just had to add some settings
ok, glad to hear it is fixed.
