Contact form Solution Kit
Thread began 12/09/2010 10:00 am by mike273103 | Last modified 12/09/2010 11:06 am by Jason Byrnes | 1433 views | 1 replies |
mike273103
Hi, I recently purchased Contact form Solution Kit and I have tried to follow your PDF file on inserting security and Captcha in to existing PHP forms. However the code you show in your pdf file and the code you say to cut and paste from the contactus.php that comes with the download do not match e.g page 3 copying CAPTCHA para 5:
Place your cursor between $WAFV_Errors = ""; and if ($WAFV_Errors != "")
You state that this was copied and pasted at an earlier stage, it was not the following is missing $WAFV_Errors = ""; it is not there in the code and is not present in your contactus.php form.
I have tried following your pdf but I can't get it to work.
I have php forms that do work and they are all within WA Siteassist websites but they do not have the CAPTCHA feature. Any assistance you can give would help.
If you would like me to send you one of my PHP forms I would be happy to email it to you.
Kind regards
MIke
to copy captcha to an existing form, copy the following code at lines 2 - 26 from the contact us page:
<?php require_once("WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
require_once("WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
require_once("WA_Universal_Email/mail_PHP.php"); ?>
require_once("WA_Universal_Email/MailFormatting_PHP.php"); ?>
if ($_SERVER["REQUEST_METHOD"] == "POST")  {
$WAFV_Redirect "";
$_SESSION['WAVT_contact_Errors'] = "";
  if (
$WAFV_Redirect == "")  {
$WAFV_Redirect $_SERVER["PHP_SELF"];
$WAFV_Errors "";
$WAFV_Errors .= WAValidateRQ(((isset($_POST["Contact_Name"]))?$_POST["Contact_Name"]:"") . "",true,1);
$WAFV_Errors .= WAValidateEM(((isset($_POST["Email_address"]))?$_POST["Email_address"]:"") . "",true,2);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["Comments"]))?$_POST["Comments"]:"") . "",true,3);
$WAFV_Errors .= WAValidateLE(((isset($_POST["Security_code"]))?strtolower($_POST["Security_code"]):"") . "",((isset($_SESSION["captcha_1"]))?strtolower($_SESSION["captcha_1"]):"") . "",true,4);
$WAFV_Errors .= WAValidateLE(((isset($_POST["Security_question"]))?strtolower($_POST["Security_question"]):"") . "",((isset($_SESSION["random_answer"]))?strtolower($_SESSION["random_answer"]):"") . "",true,5);
$WAFV_Errors .= WAValidateRX(((isset($_POST["addblock"]))?$_POST["addblock"]:"") . "","/^$/i",false,6);
$WAFV_Errors .= WAValidateRX(((isset($_POST["seconddblock"]))?$_POST["seconddblock"]:"") . "","/^$/i",false,7);
  if (
$WAFV_Errors != "")  {
PostResult($WAFV_Redirect,$WAFV_Errors,"contact");
Pate it to your page at line 1, then delete the following sections:
<?php require_once("WA_Universal_Email/mail_PHP.php"); ?>
then copy line 112 - 129 to your form:
<label for="Security_code" ><br />
    Security code:</label>
    <br />
    <img  src="WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?noisecolor=<?php echo $WAGLOBAL_Captcha_Noise?>&bgcolor=<?php echo $WAGLOBAL_Captcha_BG?>&textcolor=<?php echo $WAGLOBAL_Captcha_Text?>&transparent=<?php echo $WAGLOBAL_Captcha_BG_transparent?>&characters=<?php echo $WAGLOBAL_Captcha_Characters?>&width=<?php echo $WAGLOBAL_Captcha_Width?>&height=<?php echo $WAGLOBAL_Captcha_Height?>&font=<?php echo $WAGLOBAL_Captcha_Font?>" alt="security code" /><br  />
    <span id="sprytextfield3">
    <input name="Security_code" type="text" class="inputValue" id="Security_code" onblur="if (document.getElementById('captchaServerError')) document.getElementById('captchaServerError').style.display='none'" maxlength="40" />
    <span class="textfieldRequiredMsg">A value is required.</span><span class="textfieldMinCharsMsg">Minimum number of characters not met.</span><span class="textfieldMaxCharsMsg">Exceeded maximum number of characters.</span></span>
if (ValidatedField("contact","contact"))  {
  if ((
strpos((",".ValidatedField("contact","contact").","), "," "4" ",") !== false || "4" == ""))  {
    if (!(
false))  {
    <span id="captchaServerError" class="textfieldServerError">Your security code entry did not match the image.</span>
    <?php //WAFV_Conditional contact.php contact(4:)
    <br />
