How to: submenus above main horizontal menu?
Anybody got a method of sliding submenus above the main menu instead of dropping down below it?
this is not strictly supported.
it will only really work if your submenu are all the same length, but you can apply a negative top margin to the level one menu equal to the level one menus height.
for example, if there are 3 items in the level menu, about -87px top margin should do the trick.
