Fatal error on checkout
When try to purchase a product, and use a payment button receive the message showed in the file attached? Any suggestion for fix this issue?
Massimo
Massimo
Problem solved copied a new Wa_Store_Cart (sent by your support) in the root folder.
Massimo
ok, glad to hear it is working.
