message error on update page
Thread began 12/01/2010 5:10 am by vandenheuvel.claude346907 | Last modified 1/05/2011 7:33 pm by Ray Borduin | 1157 views | 3 replies |
creating pages with datassit 2
when i go on the upgrade page i got an error message :
You have an error in your SQL syntax near '@free.frundefined, `clt_nom` = undefinedvdhundefined, `clt_prenom` = undefinedcl' at line 1
is it normal to have on the code? :
$WA_columnTypesStr = "undefined|undefined|undefined|undefined|undefined|undefined|undefined|undefined|undefined";
____________________________________________________
// WA Application Builder Update
if (isset($_POST["Update"])) // Trigger
$WA_connection = $xxxxxxxxxxx;
$WA_table = "clients";
$WA_redirectURL = "clients_Detail.php?ID_clients=".((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:"") ."";
$WA_keepQueryString = false;
$WA_indexField = "ID_clients";
$WA_fieldNamesStr = "clt_login|clt_mdp|clt_mail|clt_nom|clt_prenom|clt_adresse|clt_ville|clt_codepostal|clt_phone";
$WA_fieldValuesStr = "".((isset($_POST["clt_login"]))?$_POST["clt_login"]:"") ."" . "|" . "".((isset($_POST["clt_mdp"]))?$_POST["clt_mdp"]:"") ."" . "|" . "".((isset($_POST["clt_mail"]))?$_POST["clt_mail"]:"") ."" . "|" . "".((isset($_POST["clt_nom"]))?$_POST["clt_nom"]:"") ."" . "|" . "".((isset($_POST["clt_prenom"]))?$_POST["clt_prenom"]:"") ."" . "|" . "".((isset($_POST["clt_adresse"]))?$_POST["clt_adresse"]:"") ."" . "|" . "".((isset($_POST["clt_ville"]))?$_POST["clt_ville"]:"") ."" . "|" . "".((isset($_POST["clt_codepostal"]))?$_POST["clt_codepostal"]:"") ."" . "|" . "".((isset($_POST["clt_phone"]))?$_POST["clt_phone"]:"") ."";
$WA_comparisonStr = " = | = | = | = | = | = | = | = | = ";
No, that is not normal, to fix the issue, double click the Update record behavior and select the proper data types for each column.
Laurent
Same problem here
Hi, i have the same probleme occuring all the time.
I guess Webassist should investigate for a bug about this....
I also notice the recorset to be buggy, there was a second static variable added (value = -1), instead of $GET[PRIMLARY KEY]
Don't know if the may be the cause of the problem, but i have an underscore in the name of my primary key (act_pk)...(and all my db fields ;-)
Do underscores produce bugs in your software ?
Regards
Underscores should not cause issues. I don't think we have been able to reproduce it, but if you are willing to work with us to help... I've opened a support incident so that we can have an engineer call and work with you over the phone directly to debug the issue.
