Is Repeat Billing Possible
Hi
Is it possible to use some form of repeat billing or notification for a member subscription site.
Any help or advice is most welcome.
Kind regards
John
Hi
Kind regards
John
Repeat billing is possible, but is not supported in eCart.
you would need to record the subscription start and end date. You would need to modify the login page to store the end date in a session variable on login. You could then create an access rule to compare to days date against the end date and send them to a repurchase page if the subscription has expired.
Hi
Thank you for you help.
Sounds complicated, Im quite familiar with code but if you know of any examples of the code i can look at that would help a grate help.
Your help is very appreciated
John
Sorry, there are not any examples of this available.
