Powerstore 2 help
I have a css modified Powerstore 2 and orders are coming through fine however they are not being saved in the orders database.
I have attached the confirm.php file.
Please help if you can.
The problem is occurring because you have changed the Submit order to a in image form field instead of a Button form element.
find the following code in 2 places:
if (isset($_POST["Submit_order"])) // Trigger
and change it to:
if (isset($_POST["Submit_order_x"])) // Trigger
Thanks Jason! I really appreciate it. I'll post to confirm it's working.
BChilds
Hi Jason,
It worked! Thanks alot. Would this be a problem on other pages as well where I'm using images on submit buttons?
I don't uderstand how adding _x to it makes it work.... can you explain?
Thanks again,
B Childs
If you want to see the full site as an example of a killer powerstore design: www.tacmedsolutions.com :-)
The image form element does not have a value attribute.
when an image for element type is used, no value will be passed, but it will pass the x and y coordinates of where the mouse clicked the image.
you can demonstrate this by creating a simple for with an image field and setting the method to get, you will see in the querystring:
?imageField.x=21&imageField.y=22
since you cant check for the image fields value, you need to check for the x or y coordinates:
if (isset($_POST["imageField_x"])
or:
if (isset($_POST["imageField_y"])
PowerStore was not coded to use an image field, it was coded to use a standard submit button.
if you swap a standard submit button with an image field, you will break the trigger code for the element.
