Adding tooltips
How can I add tooltips to the markers that show up when you hover over them. In Google Maps API 3 it's the "title:" tag.
This will require adding custom code to the google javascript file created by Pro Maps and is not supported.
I found this example through google:
custom-tooltips-for-google-maps/
if you are fluent in javascript, it should not be to difficult to modify the pro maps javascript code.
