Multiple Inserts using check boxes ASP
Thread began 6/11/2009 10:09 pm by kenp276561 | Last modified 6/25/2009 11:55 pm by kenp276561 | 1021 views | 1 replies |
kenp276561
Is there a tutorial or anything that demonstrate how to use check boxes to insert multiple records. I'm using DataAssit (ASP) and need to limit a user to 10 out of 50 records to insert using check boxes.
kenp276561
Reply from WebAssist
WebAssist sent me the following information and it worked perfectly.
Here are the steps that I took. I first made a page like you have with a form and recordset. I added bindings from the recordset to the form elements. My form included a single checkbox and a text field. I then added the standard repeat region server behavior.
When I got the repeat region in place I previewed the page to ensure that it was working as expected. Once I confirmed this I added in the DataAssist Multiple Insert server behavior. In it I selected the repeat region and for the 'skip if empty' option I choose the checkbox. I selected the table to insert into and on the next page just associated the value I wanted to be inserted into that column. In my case the value was held in a text field, but it could also come from a hidden form element if you want to have a cleaner looking display.
Once I finished this I tested the page out by saving and previewing it. I checked some of the boxes and clicked the submit button. The records that I checked were inserted without issue.
