Shipping Prices are Large, Wrong & Getting worse!
Thread began 9/25/2010 12:35 am by Awemaker | Last modified 9/25/2010 1:17 pm by Ray Borduin | 624 views | 1 replies |
Awemaker
So, I cannot get either the flat rate "Additional charge" or the "Per Item Shippng" to work in any combination. Together, either, added to the items, shipping enabled, disabled, with a shipping module or without (as I had hoped for)-- nothing no-how.
What I do get is weird: an amount which persists from transaction to transaction which is now getting larger & larger to the point that it nowhere in the ballpark. I'm using the UPS gateway and it was proven good on my last install of PS3 using the troubleshooting code
The transactions are going through, but the shipping is way wrong.
I found no real instructions on how to use it, so I started from "obvious" and proceeded to "obscure" with zero success. On the plus side, the cart adds the whacko number to the total flawlessly.
Eric
I have opened an incident to look into this issue with you as well. Please update the incident with a good phone number to contact you and we'll get in touch with you directly in order to debug and correct this problem.
