Uploade page text wrong color
Thread began 9/22/2010 1:45 pm by nickj | Last modified 9/22/2010 4:28 pm by Jason Byrnes | 491 views | 1 replies |
nickj
today,when viewing content in the HTML editor update page, all text which should be black is gold. The text displays correctly when rendered on the site so it's not the content from the database. When the update page opens the text is black (correct) then quickly changes to black.
When I highlight text and select black it stays gold.
When I insert a new record the default text color is black but when I open it in the update page it's gold again.
I can change text to red, for example, it stays red.
It appears that the update page is rendering all black (default text) in gold!
double check all of the css that is applied to the p[age, I would bet that there is css on the page causing the text to display gold.
In FireFox I would use the Web Developer Toolkit or Firebug plugin to disable style sheets one at a time to find which style sheet is causing the issue, then go through that style sheet disabling one style at a time till i found the exact style causing the gold text.
