JavaScript Error - Google Maps Pro
Thread began 9/16/2010 10:32 pm by djhimics104974 | Last modified 9/17/2010 1:28 pm by djhimics104974 | 1209 views | 2 replies |
djhimics104974
Just installed Google Maps and cannot get past the wizard. On entering Step 3 to select marker type and color and on every keystroke thereafter I get the following JavaScript error: "Error executing onClick in wagmp_map.htm. wa.markerStyles[styles] has no properties.
If I click OK to close the error box the Address Marker and Color Schemes dropdowns are empty except for a line which says "joinNL". Any selection on that page produces the same error message. Eventually I can get to the following steps but when I click FINISH I get a new error message from "wagmp_map.js that markerColor has no properties.
I have uninstalled Google Maps, deleted the .dat file, restarted the computer, reinstalled the extension and still get the error.
Any help would be appreciated - would love to get this working!
Dani Chankhour
You can try deleting the Configuration folder:
With Dreamweaver Closed, delete the configuration folder, then launch the extension manager and remove any extensions that you have installed. And then install the latest version of Pro Maps for Google.
Please post back if you are still getting the error after deleting the Configuration folder.
djhimics104974
JavaScript Error
That woud be a good solution if I didn't have about 20 of your Dreamweaver extensions installed plus 30+ from other sources which are all located in the Configuration folder.
If I delete the Configuration folder will Dreamweaver know how to recreate the required entries for the non-WebAssist extensions?
If I rename Configuration folder, can I kill off and reinstall just the WebAssist extensions then copy back the 30 non-WebAssist extensions?
