UPS Shipping Error
Thread began 6/10/2009 10:08 am by rdubill357341 | Last modified 6/10/2009 10:53 am by Ray Borduin | 1948 views | 3 replies |
rdubill357341
UPS Shipping Error
Using ASP VB...
Receiving the following error from UPS:
SHIPPING QUOTE FAILED
Missing/Illegal Service/Code
This is after I hit 'submit order' on the confirm.asp page...
The confirm.asp page is already showing the correct calculated shipping amount based on the weight of the order, the shipping destination, and the service type selected (i.e, ground, next day air, etc.)..
Any suggestions?
thanks in advance...
You can either:
1) update your trigger so that the shipping isn't recalculated after clicking the submit button on the confirm page (since the shipping is already calculated)
2) store the service type in a hidden form element or in the session so that it still exists when you do your final submit.
It appears you are probably using the submitted value from the checkout form directly to calculate the shipping and the form element isn't in the confirm page form so that it can't calculate it properly after the final submit.
rdubill357341
UPS Shiiping Problem
Thanks Ray...
Can you guide me as to where I can update the trigger to NOT recalculate shipping?
Use the form button from the previous page as the trigger and make sure the two button names are not the same from the two pages... or use the service list as the trigger since it appears it will only be set the first time.
