Completed PS3 re-install to remote server
Thread began 9/14/2010 11:48 am by robert222776 | Last modified 9/14/2010 12:17 pm by robert222776 | 876 views | 2 replies |
robert222776
I have a complete PS3 store in place on a test server, with a considerable amount of customization to the database, shopping cart, checkout, etc., to meet this customers needs. I now want to install/upload to the real server. Is there a written process for doing something like this?
I can perform a fresh install on the new server, and can use phpMyAdmin to export the sql file on the test server database and import it to the new database. I can then upload all the site files from the test server to over write the newly installed files. What would be the files that I would not want to over write? Globals? any others? Is this the right process?
Thanks,
Robert
the only files you should not over write when uploading to the live site are the connections folder.
after performing the install on the remote server, look at the wa_settings table in the database and make note of the Root URL and Local Root and remote Root settings.
after you import the local copy of the database, you will need to reset those values.
robert222776
Great! Thanks Jason.
