Search Wizard 2 Tables
Thread began 9/13/2010 1:27 pm by Cologne | Last modified 9/15/2010 1:21 am by Cologne | 1022 views | 2 replies |
Cologne
I need some help...
Can I create a search-form from 2 tables?
I would like to create a musician search.
OK, a musician cann play more than two instruments, so I store the instruments in an extra table called "instrumentSkill".
I create a selectBox from all instruments (table = instruments)
So finally I got 3 tables to check, or that I use.
the musician profile table, where is storend, age, postcode, city, email, and other general things.
then
the instrumentSkill table, where I store all the instuments and the skills of the musician
and
the instruments itself.
Is this possible?
for example:
A form to search, the instruments, city and postcode.
1 selectbox created by the instruments, and two textfields that search the musican prrofile.
I dont know how to explain.
Denis
Yes, you can create a search that uses related data however, it may require some hand editing of the search code.
You would need to create a joined query on the results page to bring in the data from both tables.
see the following site for details on creating the joined query:
sql_join.asp
Cologne
Ok, I try to make it :-)
Denis
