Only Captcha
Thread began 9/13/2010 8:16 am by Cologne | Last modified 9/13/2010 2:38 pm by Jason Byrnes | 653 views | 3 replies |
Cologne
Only Captcha
sometimes its getting very very exhausting, like inserting ONLY the captcha to my form. I tried to make the chages CSSFB did, but it does not work.
<?php require_once("../WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
<?php require_once("../WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
if (isset($_POST["buttonRegister"])) {
$WAFV_Redirect = "";
$_SESSION['WAVT_register_942_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateLE((strtolower(isset($_POST["code"])?$_POST["code"]:"")) . "",((isset($_SESSION["captcha_code"]))?strtolower($_SESSION["captcha_code"]):"") . "",true,1);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"register_942");
if(isset($_POST["buttonRegister"])){
$WA_Redirect_URL = "../index.php";
$WA_Redirect_KeepQS = false;
if ($WA_Redirect_URL != "") {
if ($WA_Redirect_KeepQS && $WA_Redirect_URL != "" && isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] !== "") {
$WA_Redirect_URL .= ((strpos($WA_Redirect_URL, '?') === false)?"?":"&").$_SERVER["QUERY_STRING"];
header("Location: ".$WA_Redirect_URL);
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<head>
<title>Registrieren</title>
</head>
<body>
<form id="formRegister" method="post" action="">
<ul>
<li>
<label for="gender">Anrede:</label>
<select name="gender" id="gender">
<option>Auswahl</option>
<option value="1">Herr</option>
<option value="2">Frau</option>
</select>
</li>
<li>
<label for="firstname">Vorname:</label>
<input type="text" name="firstname" id="firstname" />
</li>
<li>
<label for="lastname">Nachname:</label>
<input type="text" name="lastname" id="lastname" />
</li>
<li>
<label for="birthday">Geburtsdatum:</label>
<input type="text" name="birthday" id="birthday" />
</li>
</ul>
<ul>
<li>
<label for="email1">Email-Adresse:</label>
<input type="text" name="email1" id="email1" />
</li>
<li>
<label for="email2">Email-Adresse (wiederholen):</label>
<input type="text" name="email2" id="email2" />
</li>
</ul>
<ul>
<li>
<input type="checkbox" name="termsandconditions" id="termsandconditions" />
<label for="termsandconditions"><a href="#">AGB</a> & <a href="#">Bedingungen</a> gelesen und verstanden</label>
</li>
<li>
<label for="code">Sicherheitsabfrage:</label>
<img src="../WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?field=code&font=Fonts/MOM_T___.TTF" alt="Security Code" class="Captcha" /></li>
<li>
<input type="text" name="code" id="code" />
</li>
</ul>
<ul>
<li>
<input type="submit" name="buttonRegister" id="buttonRegister" value="Jetzt kostenlos registrieren!" />
</li>
</ul>
</form>
</body>
</html>
For field I only changed the name "?field=fieldset_group_Security_code" to "?field=code" cause its the label of the captcha and the name/id of the textfield.
I would be so nice, to show, how this works, without using the CSSFB that creates too much code and does not validates like I want. I only need the captcha :-(
Denis
your code looks correct. one issue I have seen that may be causing your problem is that the code form element does not have a value attribute. Change:
<input type="text" name="code" id="code" value="" />
I have a number of cases where not adding the value attribute cases the form element not to be posted.
Cologne
Hey Jason,
that works, thanks!
Denis
Great, always make sure your text boxes a value attribute.
