Any problems between eCart5 and the DreamWeaver HTML5 pack update?
Thread began 9/12/2010 7:15 pm by SaladoGuy | Last modified 9/14/2010 11:33 am by SaladoGuy | 1279 views | 5 replies |
SaladoGuyBeta Tester
For a couple months I've been working on a site using eCart and DreamWeaver CS4.
I am new to all this and just now learning how to use it. I've remade the cart from scratch a number of times, but it's always worked fairly well until today.
I originally had the eCart, DataAssist, SecurityAssist and Universal email extensions installed.
Last week, I installed all the other extensions, starting with the Cookie Toolkit.
On Friday, I installed an update that was available for Adobe DreamWeaver: the "HTML5 update pack". I can't remember if I installed any extensions after I installed that DreamWeaver update, but I do know that I had previously disabled SecurityAssist because of the bug that conflicts with the Cookie Toolkit, and I have since re-enabled SecurityAssist (which might be similar to installing it?).
Today, I backed up my site files, deleted the 3 checkout pages, and ran the Checkout Wizard again. It did create the 3 files, but they had a *bunch* of problems.
First, each one of them repeatedly redirected to the viewcart page. After manually comparing the code to the old pages, I finally found that the function "$cart->GetContent()" had been inserted in between the 2 redirect functions, instead of before them. I manually moved it before them in all 3 files, and the redirect issue cleared up.
I then had a problem on the checkout_success page where I was getting a warning about "headers already sent". I eventually found that the entire section of code responsible for sending the confirmation email was moved way down in the page. I moved it up to match the old pages and then the error went away.
There were several other bits of code that I had to rearrange in order to make the new pages work correctly.
I noticed in a few places the closing php tag of a given code block was on the same line as the opening tag for the next code block. The old pages from previous runs weren't like that.
Overall, it was a strange experience, since it had worked the previous several times.
If this had happened to me the first time I ran the wizard, I never would have figured out what was wrong. And I'm not sure how I can use this on other new sites where I won't have an "old working copy" to compare against. It seems that eCart is now simply generating incorrect code on my computer.
Which makes me wonder - is there some incompatibility between eCart and the DreamWeaver HTML5 update?
Please let me know if I need to provide any more information.
Thanks.
Originally Said By: SaladoGuy
I'm sorry, that was supposed to read "and DreamWeaver CS5", *NOT* CS4
I can confirm that on another computer that also has the CS5 HTML5 update installed, eCart now has exactly the same problem as on my computer (generating code with the same problems). FYI these are both Macs, running Snow Leopard. At the moment I don't have another computer test on.
I was not able to reproduce a similar problem using Dreamweaver CS5 after installing the 11.0.3 Dreamweaver update. The checkout pages created by the checkout wizard did not have the code order problems that you mentioned.
Thank you Jason. I'm still working on it.
We stup a fresh DreamWeaver install on Windows (and did not apply any updates) and we're still having the same problem, so it's not a problem with the DW update.
I'm assuming that there must be some problem with our cart object now, and it's causing the checkout wizard to generate bad code. I'm going to try purging all the eCart related code and starting fresh.
