Headers already sent with SSI
hello im trying to build a site that has the login on the header all the time if the user has not log to the site, i created a php file for the header where i have made a form and added the security assist authenticate user, then i have a template for all pages where on the top i use an include the header file but when i do this i always get a blank page with this msg:
Warning: Cannot modify header information - headers already sent by (output started at C:\xampp\htdocs\artppl\index.php:55) in C:\xampp\htdocs\artppl\WA_SecurityAssist\Helper_PHP.php on line 38
Now i know to check for empty spaces wich i did, the only thing i see is that if i insert the header in the template like this
<div id="OuterWrapper"><?php require_once('../head.php'); ?><div id="InnerWrapper">
<div id="Contents"> <!-- TemplateBeginEditable name="CenterRegion" --><!-- TemplateEndEditable --></div>
i get the error is there any way to work this around?
I attached the file of picture of what i want to acomplish i know that if i use addt server side includes would work but trying to be less dependant to addt and still have not been able to get the new WA framework just trying to do a manual include but with no luck
