Errors when opening DW
Thread began 9/10/2010 1:29 pm by MBH | Last modified 9/10/2010 2:46 pm by Jason Byrnes | 1905 views | 3 replies |
MBH
Hello -
Any information or direction would be greatly appreciated. I'm receiving the following errors when opening DW8:
The following translators were not loaded due to errors:
ASP.htm has configuration information that is not valid.
XSLT.htm has configuration information that is not valid.
I've run the DW install/repair, and downloaded and reinstalled two of the several WA extensions we use, which hasn't solved the issue. Not sure where to go from here.
Thank you in advance for any assistance.
Regards,
MBH
to fix the errors, rename the Dreamweaver configuration folder. for help locating the configuration folder, see the common installation issues pdf:
What version of the extensions are you installing?
MBH
Jason,
Thank you very much. I'll read and work through the tech sheet you posted.
Extension Versions ~
Universal Email—4.05
CCSSculptor - 2.05
CCSMenuwriter 2.05
WAeCart—4..1.4
SiteAssistPro 1. series
DataAssist 1.31
DigitalFile 1.13
We have the Toolkit, PayPal, Google, Surveyor, and a couple more. We’re more than satisfied with WebAssist.
Thanks again,
MBH
Universal Email version 4 will not work in DW version 8 . it is only compatible with DW Cs3 and above.
you will need to upgrade your Dreamweaver version to use version 4 of Universal Email.
