Labels did not line up
Thread began 9/09/2010 10:15 am by michaelf0199272 | Last modified 9/09/2010 2:11 pm by Jason Byrnes | 1054 views | 3 replies |
michaelf0199272
The label below is what I am trying to line up in a symetrical manner.
© 2010 www.afomampi.com Design by XcelData
when I implemented it using <div> or <SPAN> the "Design by XcelData" did not seem to be on the same line as the copy right message -- Both the <div> and the <SPAN> implementation produced the same resolve.
Please the see the attached image. Also see the code that produced the image below.
<div id="footer">
<!-- Please leave this line intact -->
<!-- you can delete below here -->
<div> © 2010 www.afomampi.com </div><div style="float: right">Design by <a href="http://www.xceldatatechnologies.com" target="_blank">XcelData</a></div></div>
</div>
Note: I did not want to use space to seperate the two by using multiple "&nbsp;" and I also did not want to use table.
Q: Does anyone here know what I am doing wrong which did not make the two disjoint statements to be on the same line???
Many thanks in advance.
you need to float the first div to the left:
<div style="float:left;"> © 2010 www.afomampi.com </div>
michaelf0199272
Many thanks, I will try it later tonight.
you're welcome.
