Changing to Linux host server caused the buttons on cart page to stop working
Thread began 9/08/2010 10:22 am by georgevargasa302189 | Last modified 9/08/2010 4:18 pm by Jason Byrnes | 876 views | 8 replies |
georgevargasa302189
I changed my host server on GoDaddy to Linux to get PHP mail to work. The good news is that that works now and I get the confirmation emails.
The weird news is that my shopping carts buttons; 'continue shopping' and 'checkout', just redirect to the shopping cart, instead of going to the right place.
The same page works fine on my local server.
If I go to checkout with a different link. it actually completes the checkout process.
I tried to change the server beheavior for the continue shopping to uncheck the 'if exists' box and link to my directly to shopping page, but it still fails.
Any ideas?
georgevargasa302189
Here is some additional info.
I turned on PHP error reporting and I see the following error when I go to the Cart page,
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/content/g/e/o/georgevargas1/html/shoppingcart.php:5) in /home/content/g/e/o/georgevargas1/html/WA_eCart/WA_eCart_Definition_PHP.php on line 465
Also when I hit the continue shopping button I get,
Warning: Cannot modify header information - headers already sent by (output started at /home/content/g/e/o/georgevargas1/html/shoppingcart.php:5) in /home/content/g/e/o/georgevargas1/html/shoppingcart.php on line 167
shoppingcart.zip
as the error says, the output started near line 5:
At line 4 you have a blank space at the end causing the error:
remove the blank space at the end to fix the error.
georgevargasa302189
ok that gets rid of the error messages, but the originaly problem in the first post is still occuring.
Any Ideas?
send the most recent copy of your page.
when I try the continue button, I get the following error:
Warning: Cannot modify header information - headers already sent by (output started at /home/content/g/e/o/georgevargas1/html/shoppingcart.php:62) in /home/content/g/e/o/georgevargas1/html/shoppingcart.php on line 65
there is output to the page at line 62.
georgevargasa302189
I also noticed that on the local server the checkout button on the cart page does not work now either. It may be that this is unrelated to the change of host to Linux. The last thing I was playing with was the setting the email port number to 25.
Here is the latest page.
shoppingcart.zip
the checkout link does not work because there is no page specified in the checkout server behavior to redirect to.
the error is occurring because of a blank line in the code.
at line 57, there is a blank line between code blocks that needs to be removed:
56- ?>
57-
58-<?php
in the server behaviors tab, double click the checkout server behavior and specify a page to direct to for checkout.
georgevargasa302189
Thank you very much!!! I have no idea how that happened.
It now works fine on the server!
you're welcome.
