Point link target to iframe
Thread began 9/04/2010 2:35 pm by Miguel | Last modified 9/07/2010 7:33 pm by Miguel | 3045 views | 4 replies |
Miguel
Hello im making a series of graphs wich are small and i want to link them to a general page inside an iframe where i have them big, im using the point link to link them to another page, but how can i target them to a specific frame or iframe?
<value><?php echo($row_WADWCplanes_prod['YVALUE']); ?></value><pointlink>stat_min_price.php</pointlink>
anonymous
Sades,
The best way to do would be to use a a hyperlink and target the actual frame.
Let's say you have two frames on your page - one that is Small and one that is Big. Make sure you add the name attribute to your frames - for this example - name the small one "Small" and the big one "Big".
Then just make your hyperlink as such:
<a href="samepage.htm" target="Big">Hyperlink text or image here</a>
Just make sure if you are staying on the same page that you define the same page in the href attribute or use "#" instead.
Regards,
Brian
Miguel
Hello sojo i mean in dynamic web charts that code is for html, on webcharts we have something to make each node of the grafic be able to link using
<pointlink>file.extension</pointlink>
the one you placed here
does not work cause remeber its a link inside the flash chart with the pointlink comand inside the xml is the way to go but i have tried
html:
<pointlink target="framename">file.extension</pointlink>
with no luck guess ill have to download the open chart and modify the fla they give
Dynamic Flash charts does not support passing a target attribute with the link.
Miguel
ok thank you for the response guess ill have to figure a difrent way
