custom shipping conundrum
Thread began 9/02/2010 11:29 am by CraigR | Last modified 9/02/2010 1:17 pm by CraigR | 544 views | 2 replies |
CraigRBeta Tester
My client has a store where goods are sent by ground or air
They would like to separate bulky items, so that they may be sent by ground only.
If an order consisted of one 'bulky' item and several 'standard' items, and the customer chose air freight, the order would be sent in 2 lots, the bulky item by ground and the standard items by air.
my client has shipping charges calculated by cart subtotal, $0-$50, $50-$100 etc.
I don't believe it's possible to apply a negative shipping charge rule, but the pseudo logic would be..
"If an item of category 'bulky' is in the cart, subtract its value from the cart subtotal when evaluating the shipping calculation."
Is there a way to do this without lots of hand coding ?
** I could probably do this calculation within the 'discounts' tab, but would like the calculation to be under 'shipping'
You can do a negative shipping charge. Many of the rules allow you to multiply the charge by a number, just use -1 and it should make your charge act as a discount or just pass in a negative number and it should work.
CraigRBeta Tester
thanks Ray.
I worked out the reason my negative charge (discount) didn't appear to be working, was that it was greater than the actual shipping amount, so that the overall total was less than zero.
