label name field name
hi,
as i can see, the fieldname is the labelname, too. right?
is there a way to change that. i need german for the labels and english for the fields.
cheers, denis
hi,
cheers, denis
No, CSS form builder does not have a way to separate the labels from the element names.
you would need to change this manually after the form is created. Create the form using English labels, then translate them to German after the form is created using design view in Dreamweaver.
but the i cant re enter and edit with the form builder, right?
yes, that is correct, reentering form builder will override your label changes. this will need to be the last step in your design.
