Script Errors
Thread began 8/31/2010 1:44 pm by landarts320555 | Last modified 9/02/2010 6:20 am by Jason Byrnes | 1147 views | 5 replies |
landarts320555
Script Errors
I am having a great time with script errors while trying to get the hang of site sculptor. First let me say that I have on multiple occasions gone back in and deleted the ****.dat file as noted in the suggestions for the fix. I am running Dreamweaver CS3 on a windows 7 computer. This is the only piece of Webassist software that I have that will not run properly. All of the other extensions that I use work flawless. Here are a few screen shots of those error codes....any light on the subject will really help.
image 1 & 2 happened in the start of the program, image 3 happened toward the end while its trying to make all files.
Jim
look like you have created a custom site type that includes some jquery or other javascript that is not functioning correctly in IE.
before saving your design as a template, you should make sure that you can browse the fie properly in IE.
you may be able to get around the issue by disabling the preview, or disabling the option ot show every javascript error in IE.
landarts320555
response
Jason, thanks for the reply...here is the site that is live on the internet. Here is a link to the site live on internet explorer www.eaglepto.com/. Everything seems to run fine on ie.
Jim
but what about the template?
can you browse the template in IE without errors?
landarts320555
You can't load a dwt template into a browser?
you can rename the template to .dwt.php or .dwt.htm to load it in the browser for testing.
