Update Multiple Records that include file upload
Thread began 8/30/2010 7:46 am by pmait97856 | Last modified 8/30/2010 11:21 am by Jason Byrnes | 622 views | 3 replies |
pmait97856
I have successfully created an update form that includes a file upload.
I also need to create a multiple record update that does the same thing. Everything works with the exception of the file field. On submitting the form, the db table gets an empty entry. Plus the server validations are not working, probably because I am using the same validation code as the single update record.
Is there a different technique when doing this for multiple records than for single records?
Below is the WU Update code:
// WA DataAssist Multiple Updates
if (isset($_POST["Update_x"])) // Trigger
$WA_loopedIDField = array("WADA_RepeatID_pFolioImg_id");
$WA_connection = $joshHannaDB;
$WA_table = "pFolioImage_Joshua";
$WA_redirectURL = "pFolioImage_Joshua_Results.php";
$WA_keepQueryString = false;
$WA_indexField = "pFolioImg_id";
$WA_fieldNamesStr = "pFolioImg_CatID|pFolioImg_Filename|pFolioImg_Title|pFolioImg_Details|showAsRecent|pFolioImg_UdateDate|pFolioImg_Active";
$WA_columnTypesStr = "none,none,NULL|',none,''|',none,''|',none,''|',none,''|',none,NULL|',none,''";
$WA_connectionDB = $database_joshHannaDB;
$WA_multipleUpdateCounter = 0;
while (WA_AB_checkLoopedFieldsNotBlank($WA_loopedIDField, $WA_multipleUpdateCounter)) {
$WA_fieldValuesStr = "".WA_AB_getLoopedFieldValue("pFolioImg_CatID", $WA_multipleUpdateCounter) ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"] ."" . "|" . "".WA_AB_getLoopedFieldValue("pFolioImg_Title", $WA_multipleUpdateCounter) ."" . "|" . "".WA_AB_getLoopedFieldValue("pFolioImg_Details", $WA_multipleUpdateCounter) ."" . "|" . "".WA_AB_getLoopedFieldValue("showAsRecent", $WA_multipleUpdateCounter) ."" . "|" . "".WA_AB_getLoopedFieldValue("pFolioImg_UdateDate", $WA_multipleUpdateCounter) ."" . "|" . "".WA_AB_getLoopedFieldValue("pFolioImg_Active", $WA_multipleUpdateCounter) ."";
$WA_where_fieldValuesStr = WA_AB_getLoopedFieldValue($WA_loopedIDField[0], $WA_multipleUpdateCounter);
$WA_where_columnTypesStr = "none,none,NULL";
$WA_where_comparisonStr = "=";
$WA_where_fieldNames = explode("|", $WA_indexField);
$WA_where_fieldValues = explode("|", $WA_where_fieldValuesStr);
$WA_where_columns = explode("|", $WA_where_columnTypesStr);
$WA_where_comparisons = explode("|", $WA_where_comparisonStr);
$updateParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WhereObj = WA_AB_generateWhereClause($WA_where_fieldNames, $WA_where_columns, $WA_where_fieldValues, $WA_where_comparisons );
$WA_Sql = "UPDATE `" . $WA_table . "` SET " . $updateParamsObj->WA_setValues . " WHERE " . $WhereObj->sqlWhereClause . "";
$WA_multipleUpdateCounter++;
if ($WA_redirectURL != "") {
And here is the validation code:
if (isset($_POST["Update_x"])) {
$WAFV_Redirect = "portfolioJoshua_updateMulti.php?invalid=true";
$_SESSION['WAVT_portfolioJoshuaupdateMulti_632_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateNM(((isset($_FILES["portfolioImage"]))?$_FILES["portfolioImage"]["size"]:"") . "",0,1500000,"",",.",false,1);
$WAFV_Errors .= WAValidateFE(((isset($_FILES["portfolioImage"]))?$_FILES["portfolioImage"]["name"]:"") . "",".gif, .jpg, .jpeg, .png",false,2);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"portfolioJoshuaupdateMulti_632");
I have also attached the actual page.
Any help will be greatly appreciated.
portfolioJoshua_updateMulti.php.zip
The file upload is not supported with the multiple update server behavior, this functionality is not supported.
pmait97856
Wish list
That's a shame because the multiple insert and update behaviors are very useful.
It would be great if WebAssist would consider adding multiple file uploads in a future update.
you can post any wishlist ideas to the feedback form:
feedback.php
or the wishlist forum:
forumdisplay.php?f=8
