Getting started
Thread began 8/26/2010 10:08 am by buddy373828 | Last modified 8/30/2010 10:25 am by Jason Byrnes | 2746 views | 11 replies |
buddy373828
Getting started
Some of my pages work and dreamweaver sees the database but when I try to view users_registration_simple.php I get the following error messages.
Warning: require_once(WA_Globals/WA_Globals.php) [function.require-once]: failed to open stream: No such file or directory in D:\wamp\www\users_Registration_Simple.php on line 1
Fatal error: require_once() [function.require]: Failed opening required 'WA_Globals/WA_Globals.php' (include_path='.;C:\php5\pear') in D:\wamp\www\users_Registration_Simple.php on line 1
the line to attach the globals file should look like:
<?php require_once("WA_Globals/WA_Globals.php"); ?>
has this been changed?
what is that line set to on the profile page?
buddy373828
Not changed
<?php require_once("WA_Universal_Email/mail_PHP.php"); ?>
<?php require_once("WA_Universal_Email/MailFormatting_PHP.php"); ?>
require_once("WA_SecurityAssist/WA_RandomPassword.php");
<?php require_once('Connections/localhost.php'); ?>
<?php require_once("WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once("WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
<?php require_once("WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
Is that the code from the profile page?
what is the code in the registration page?
can you provide a link?
buddy373828
That's the code from the users_simple.php
I am testing using wamp on my machine
buddy373828
I am testing on my local machine so I can't provide a link. Can you connect with my computer and see what I am doing wrong?
Thanks,
does the WA_Globals file exist at D:\wamp\www\WA_Globals\WA_Globals.php? where did you extract the other files for the user registration solution pack?
buddy373828
WA_Globals file is at d:\wamp\www\userregister\WA_Globals
other files are all at same place.
thanks
buddy373828
I copied file and put WA_Globals file at D:\wamp\www\WA_Globals\WA_Globals.php? and still get the same error. I googled this error and find that a lot of people have had it but I could not find a solution. I need to get this working this coming week. What else can I try?
Thanks,
Buddy
buddy373828
profile page
<?php require_once( "WA_SecurityAssist/Helper_PHP.php" ); ?>
Thanks,
Buddy
