Image File Upload Problem
Thread began 8/26/2010 9:00 am by vincent.rycx336448 | Last modified 8/27/2010 7:12 am by Jason Byrnes | 961 views | 4 replies |
vincent.rycx336448
I cannot upload files larger than 1M. from my websites to my server.
This is the message I get.
Fatal error: Allowed memory size of 41943040 bytes exhausted (tried to allocate 3452 bytes) in /home1/arhezoin/public_html/webassist/file_manipulation/helperphp.php on line 865
This is the content of my php.ini file
post_max_size = 5M
upload_max_filesize = 5M
max_execution_time = 600
max_input_time = 600
memory_limit = 40M
Thanks for the help.
Vince
are these image files?
are you doing any resizing?
if you are resizing the images, the GD library will need to use a considerable amount of memory.
add the following to line 1 of the page to increase the memory limit setting:
ini_set
('memory_limit''256M');
vincent.rycx336448
That makes it work on that server.
I have another site hosted by 1and1.com, where I can't make the application work.
It seems that I cannot allocate more than 40M memory.
Does that make sense ?
vincent.rycx336448
I got a reply from 1and1.com.
They will not provide for more than 30M on share hosting.
Not much to do I guess.
Vince
yes, unfortunately this will mean the image resizing in file upload will not work with 1and1.
