Best solution for Multilingual website
Hi all,
Is it possible to create a multilingual website using Site Sculptor? If not any ideas? -
Regards
Aled
Hi all,
Regards
Aled
You create 2 separate websites, one for each language.
It may be more viable using PowerCMS upgrade. You could have duplicate content regions for lets say "english" "french" then set a session variable using a selector on the page somewhere. Then show/hide regions depending on that variable.
Just an idea.
Mike
Mike's suggestion is a good one.
i have done this by setting a session variable for the selected language, and all of the 'content' using php includes, the relevant one loading depending on the current session variable.
with a bit of code tweaking, you should be able to use power cms to achieve the same thing.
maybe this could be a good use of the framework extension ??
