Error when adding
I get an java error, wehn I add the SiteSculptor pages. It got something to do whith the DMX extension :-(
Can you check that please.
Denis
Denis
Seams there is a compatibility issue with the DMX Sliding Panels extension. Can you try disabling the sliding panels extension to see if that resolves the error, If that resolves the error, I will log a bug so we can investigate the cause of the incompatibility.
When I turn the DMX panels off, it works fine. But the DMX panels works well, if site sculptor is off, too :-(
OK, I will log a bug so we can look into why the two are not compatible, we will have to address this issue in future update.
Anything new?
When I try to use the extension, it makes action to the DMX SlidingPanel :-(
And it stops with that JavaScript error.
I should ask, why WA tries to use the DMX file?
By the way, the page will be created, but the error is not so nice :-)
If you need more information, let me know.
Cheers
Denis
This has been logged as a bug, and should be fixed when an update is released.
The issue is most likely that there are server behaviors that are named the same in the DMX extension and Site Sculptor.
