Problem with primary keys...
Thread began 8/20/2010 11:57 am by blackweldermhe400113 | Last modified 8/20/2010 12:07 pm by Jason Byrnes | 978 views | 1 replies |
I have two tables in my database. One is for audio CDs and the other is for greeting cards. They both individually apply to the cart fine, but if two products from different tables have the same primary key, which will happen when auto incrementing, they act as one item and create a sum of the two as one item instead of two unique items in the cart. I've checked my bindings on the add to cart buttons and everything appears to be fine. Any ideas?
you shouldn't be using 2 different tables, you should use the same table for both products.
you can separate the products into different categories by adding a productCategory column to the main products table.
