Search not working in IE when enter key is pressed
Thread began 8/18/2010 2:26 pm by tn228553 | Last modified 8/18/2010 3:59 pm by Jason Byrnes | 1354 views | 3 replies |
tn228553
Okay, this is going to drive me NUTS...I can't figure this one out. I have the attached form that works fine when I enter the search field and click submit or hit enter in FF.
When I go over to IE it ONLY works when I click on the actual submit button? I tried to add a hidden field based on another post like this: <input name="WADbSearch1" type="hidden" value="WADbSearch1" />
and it still did not work, what am I missing?
Thanks in advance!
reregistration_ResultsWA.zip
double click the DataAssist search server behavior.
click the lightning bolt next to trigger and select the S_Nnumber form element.
tn228553
Trigger
Perfect, thanks! I wonder why WA compiled it that way?
the search is always created t use the the search button as the trigger.
it only becomes an issue in searches that only use one field.
