works but not with site pages using WA Security
Thread began 8/17/2010 5:35 pm by Francois | Last modified 8/19/2010 10:01 am by Jason Byrnes | 535 views | 3 replies |
Francois
I installed v2 ok, and it works fine on a new blank page but not with site pages using WA Security - all my pages have a first line <?php require_once( "../WA_SecurityAssist/Helper_PHP.php" ); ?>
The page works only when I remove that line.
This is because PowerCMS also includes security assist users to authenticate.
you can get around the issue by saving a copy of the WA_CMS.php as WA_CMS2.php
in the WA_CMS2.php file, comment out the line to include the security assist helper:
//require_once( "../WA_SecurityAssist/Helper_PHP.php" );
and use the WA_CMS2.php file on the security assist pages.
Francois
1. what do you mean "and use the WA_CMS2.php file on the security assist pages"?
2. do you mean to make a search and replace for the powercms files calling for it and change it to 2?
3. if so, can I not just comment out the line in WA_CMS.php and no need to change the links to 2? I tried this and it works. What do you think? I'll test it out more,
Sorry, i meant in the addtosite.php page, change:
include_once($abs_prefix . 'WA_CMS/WA_CMS.php');
include_once($abs_prefix . 'WA_CMS/WA_CMS2.php');
but i guess your solution of changing it in the WA_CMS.php file is a bit simpler ;) that solution will work just as well.
