500 Internal Server Error
Thread began 8/17/2010 2:27 am by steve.whipp403924 | Last modified 8/17/2010 7:26 am by Jason Byrnes | 615 views | 1 replies |
steve.whipp403924
I have set up a PHP webpage with goolge maps on map.php
I have enabled PHP on the web server and can see other PHP pages perfectly well. But this map page give me a 500 error.
Does anyone know why this may be?
(I have set the API code to tie into teamfittogether.org)
the 500 Internal Server Error is a default error tht will be shown if error reporting is turned off.
It is a very vague error and is impossible to troubleshoot.
We need to know what the real error is to be able to have an idea of what is wrong.
You may be able to add the following code at line 1 to display the error:
error_reporting
(E_ALL);
if that does not display the error, you will need to contact the host to gain access tot he servers error logs to find the error.
Once we know the error, we can begin troubleshooting the cause.
