Cart Items Get Deleted
Every time I add a product to the shopping cart and try to purchase the item in Paypal, the cart is emptied and I have to add the product again.
This happens every time.
what is the full address in the address bar when you first have items in the cart?
What is the full address in the address bar when the cart is empty?
Please copy and past these two addresses from the address bar for comparison.
My guess is that the domain is changing
this can happen if you access your site at:
www.mydomain.com
but paypal redirects you back to
mydomain.com
these are not treated as the same domain by the session cookie, so a new session will be started.
Address with items in cart: cart.php
Address without items in cart: cart.php
How do I make the URLs the same?
in the powerstore database, check the Root URL in the wa_settings table, make sure the Root Url is "http://www.acbyd.com/"
In my database table the website URL is cart.php
Every time I use the cart, the URL is changed to cart.php and my cart fails.
Amy ideas?
Then the next time through, I get a Checkout Transaction Failure.
have you made any changes to the cart, checkout or confirm pages?
the return url should be set on the checkout page:
$WA_PP_ECO_Set_params[0][$nextIndex] = "ReturnURL";
$WA_PP_ECO_Set_params[1][$nextIndex] = "".$WAGLOBAL_Root_URL ."pp_confirm.php";
maybe try replacing the checkout page with the original one from the power store download.
I just replaced everything and the URL is still getting changed after I login to Paypal to confirm the order. I've never had this problem before.
website: www.acbyd.com
I attached the files.
