changing main store image
Customer wants to change the stores large main image which is now blue with the artistic lines. What file do I access to change this image to a custom image?
That image is stored under the images folder and it is called: storeMessage_bg.png.
If you wanted to change some of the CSS Properties, you can do that in the home.css file which is located under the css folder.
in css/home.css
edit the background-image property of the storeMessage selector to change that image to your own:
#storeMessage {
background-image: url("../Images/storeMessage_bg.png");
background-repeat: no-repeat;
height: 260px;
margin-left: 1px;
overflow:hidden;
background-color: #06245c;
margin-right: 1px;
