Name of Table is wrong :-(
Thread began 8/15/2010 3:01 pm by Cologne | Last modified 8/18/2010 9:51 am by Jason Byrnes | 885 views | 3 replies |
Cologne
Hi there,
I use the newest version of DA.
My table is called USER. When I use DA, the table ist namen "'USERS'" and tha causes an ERROR.
$WA_table = "'USER'";
I always have to change by hand :-(
Cheers
Denis
I have logged a bug for this.
Basically the issue is that "user is a reserved word by the ODBC drivers used for connecting to an Access database. our code is trying to hard to prevent errors when a reserved word is used.
it is forcing the "`" marks around the table name, but those tick marks are hard coded into the query:
$WA_Sql = "INSERT INTO `" . $WA_table . "`
it should do one or the other, but not both. thanks for bringing this to our attention.
Cologne
Hi Jason,
when I changed to "MEMBER" everything is fine.
Denis
It will also work as expected if you name the table "users".
ther is a list of reserved words that it will compare against. Where DataAssist 2 supports ASP and ColdFusion as well as php, the list included MSSQL, ODBC, Access and MySQL reserved words. 'user' is on the ODBC list. 'users' is not on any list.
