Error Generating Menu
Thread began 8/14/2010 11:28 pm by dave.klotz357236 | Last modified 8/17/2010 10:09 am by Jason Byrnes | 729 views | 4 replies |
dave.klotz357236
My Menu Writer was working perfectly until I had to reinstall my Ecart 4, now I am getting the following error:
Error Generating Menu (wa.generate.menu):
Type Error:
MM.WA_CreateProcessing object not a function.
If I follow the install PDF, will I lose all the other menu's that I have created?
This is crazy, I install E-Cart and then my Menu Writer doesn't work, so now when I get the Menu writer fixed, my E-cart will probably stop working.
Delete the Dreamweaver Cache file from the users configuration folder:
this will not have any effect on the menus you have created, and will not break eCart either.
dave.klotz357236
As stated in the original post I did that, but I have no WinFileCache.dat in the configuration directory
dave.klotz357236
Never mind, I was looking in the wrong directory - working now
glad to hear it is working.
