Uploading database
Hi
I'd like to start remote testing starting with a contact page.
I've connected and uploaded the site and it navigates.
How do I upload the accompanying database?
Sabby76
Hi
Sabby76
In general the idea is that you need to export the db as a .sql file using a MySQL tool like SQLyog or phpMyAdmin or something like this. If you are on a mac you should take a look at sequel pro, it is pretty simple and easy to use. Once you have exported the db as a .sql file you can then use the database management area of your live server to import the .sql file. Here is a guide on importing the db:
importing_sql.pdf
We also have the Database Starter Kit that gives you a bit of helpful info for managing a MySQL db, it can be found on our free tutorials and training section of out site:
database-for-php/
Hi Eric
Thank you for your reply
I will have a play with phpMyAdim.
I use a PC for the home and a g4 mac book for roaming.
Sabby76
