Yes and No
Thread began 8/12/2010 11:40 am by esms | Last modified 8/12/2010 4:08 pm by esms | 1643 views | 4 replies |
esmsBeta Tester
Yes and No
Each time I install a WA extension (because I have so many I assume), the installer asks if I want to overwrite existing files that are NEWER or OLDER. See screenshot. This can get tedious with 50 clicks for some installations.
Can there be a button that states: Overwrite OLDER files but keep NEWER files.
Cheers.
Anna Robinson
You should click the Yes to All button whenever installing a WebAssist extension.
esmsBeta Tester
Originally Said By: Anna Robinson
Even though the text states a newer version is already installed?
Incidentally, I've never had a WA prog fail because of this - it's just a bit of a pain having to manually click every jpg file etc...
Anna Robinson
Yes, you can disregard the timestamps on those files and always click Yes to All.
esmsBeta Tester
OK - thanks.
