eCart error when loading Dreamweaver
Please see attachment
To get past this error you should make sure to delete the dat file, here are the instructions for this:
If this does not resolve the problem then your configuration may be corrupted, if this is the case you will need to follow the instructions here:
showpost.php?p=12293&postcount=2
Post back and let us know if this does not resolve the issue for you.
Thanks a TON Eric! that worked (option 1)
Erick Lewis
