Framework and Site Sculptor?
Thread began 8/12/2010 6:22 am by MikeH | Last modified 8/12/2010 10:12 pm by Ray Borduin | 1205 views | 10 replies |
MikeH
Hi
Can a Site Sculptor site be used with the new Themes and Plugins with out a problem?
Ie Can the DW template used in the sculptor site be changed to a Dynamic theme or would this cause problems?
Mike
It should work without problems.
MikeH
Thanks Ray.
MikeH
Not sure if its me or what but when I create a theme from the Sculptor template I get asked if I want to apply the theme at the same time to the other pages so I say "yes" so the extension does it stuff and loads all the pages into DW but apart from the includes that are added the template areas are still in the source is this correct?
Mike
Yeah.... I actually just logged a bug that we should strip out the content.
It will work as it is, and if you make a change the the theme and apply it to all pages it will remove it.
Technically it is not correct, but it should still work properly. It actually updates it to be bound to the theme template, but never applies the new template so the design will look the same.
MikeH
When you say make a change to the theme do you mean the original template ?
I did try that and then DW says update all pages assosicated with the template?
Thanks for any help Ray.
Mike
Update the theme and say "yes" to update all pages. That will make the theme template update the page and strip it of all the original content.
MikeH
Ray how do you update the theme?
Tnx
Mike
Just open it up, add a space, and save. It will ask you if you want to update all pages and say yes.
MikeH
Ray this the .dwt file we are talking about so how does it now differ from just using the original template i would still have to upload all pages wouldnt I?
Mike
