Error when file attempts to download...
Thread began 8/12/2010 4:26 am by blackweldermhe400113 | Last modified 8/12/2010 10:13 am by Jason Byrnes | 680 views | 1 replies |
I've applied the dfp download function to a button on my audio page following the instructions from the "How to create a download center" tutorial. When ever I hit the download button the browser stops responding for a moment the dumps the following error along with a bunch of strange code. I can tell that the file is mapped correctly because I can pick out the name of the file in all of the junk code. The error is as follows:
Warning: Cannot modify header information - headers already sent by (output started at C:\xampp\htdocs\yourWorkingCopy\audio.php:6) in C:\xampp\htdocs\yourWorkingCopy\WA_DigitalFilePro\HelperPHP.php on line 688
Warning: Cannot modify header information - headers already sent by (output started at C:\xampp\htdocs\yourWorkingCopy\audio.php:6) in C:\xampp\htdocs\yourWorkingCopy\WA_DigitalFilePro\HelperPHP.php on line 689
Warning: Cannot modify header information - headers already sent by (output started at C:\xampp\htdocs\yourWorkingCopy\audio.php:6) in C:\xampp\htdocs\yourWorkingCopy\WA_DigitalFilePro\HelperPHP.php on line 690
Warning: Cannot modify header information - headers already sent by (output started at C:\xampp\htdocs\yourWorkingCopy\audio.php:6) in C:\xampp\htdocs\yourWorkingCopy\WA_DigitalFilePro\HelperPHP.php on line 691
I've attached the file also. If you could help I would greatly appreciate it.
James
audio.zip
The Headers Already Sent error occurs if there is any out put to the page before the header() or session_start() functions are used.
you can use the error text to help find where the issue is on the page:
means that the output that is causing the error is in the audio.php page around line 6, probably the line before it (5).
On line 5 I see that there is a blank space after the closing PHP tag:
it is this blank space that is causing the error.
remove that blank space at the end of line 5 to fix the problem.
