Any potential conflict using same object name ?
Hello i'm testing nested plugins with WA Framework and it found run well.... GREAT !
The structure:
A.php --> B.php --> C.php
A.php will include B.php as plugin
B.php will include C.php as plugin
your default object name is : $WA_xx_1 (or something like this)
i test B.php and C.php with the same object name as A.php and it found no problem and it work well , however i would like to know if there any potential conflict if i use same object name for nested plugin (not at the same page)...
Why i use the same object name, because i found it faster to create dreamweaver snippet and change the filename manually...
