Editing Center.php
Thread began 8/11/2010 2:59 am by rmruda390861 | Last modified 8/12/2010 10:41 am by Jason Byrnes | 549 views | 3 replies |
rmruda390861
Editing Center.php
My form is working fine. Email arrives fine as expected.
I used your "Create a file for your email" webassit/email/template/Center.php.
I am at a loss as to how to edit this form.
There are no Sever Behavous or Bindings.
I need to be able to edit the actual field names printed on the form, for example "Contact Me group First Name:" to make them more presentable.
I am able to go back into univesal email via Server behavious and create new forms from your templates and of course can edit the basic layout but not the "php"
Richard
the center php page uses a loop to go through each form field that is posted and write its value, the label uses the form elements name, you edit the code that writes the form label to change "Contact Me group First Name" to be just "First Name"
The code in the center.php page to write the label will look like:
<th style="font-size: 10px;font-family: Arial, Helvetica, sans-serif;width: 134px; text-align: right; padding: 3px 10px 3px 3px; color: #FE6C00; font-weight: bold;"><?php echo(str_replace("_"," ",$pkey)); ?>:</th>
you can change it to:
<th style="font-size: 10px;font-family: Arial, Helvetica, sans-serif;width: 134px; text-align: right; padding: 3px 10px 3px 3px; color: #FE6C00; font-weight: bold;"><?php echo(str_replace("_"," ",str_replace("Contact_Me_group_"""$pkey))); ?>:</th>
This will strip the "Contact_Me_group_" string from the form elements name leaving only "First name"
rmruda390861
Thanks Jason - worked OK.
Is there anyway to limit the fields displayed with the template...
For example to remove the Hidden fields and the submit button. Sure I can do this with a custom form but what about the built in templates?
neear the top of the page, there is the following code:
$remove = array();
$remove[]  = "";
$remove[]  = "x";
$remove[]  = "y";
this is an array of form elements that will be removed from the email. add the name of any form element that should not be incused in the email to the array. for example, if you have a hidden form element named "My_Hidden_Form_Element" that you dont want to show in the email, add a new node to the array:
$remove = array();
$remove[]  = "";
$remove[]  = "x";
$remove[]  = "y";
$remove[]  = "My_Hidden_Form_Element";
