CSS Form Builder Problem
Thread began 8/10/2010 1:59 pm by joemagda373194 | Last modified 8/11/2010 3:11 pm by Eric Mittman | 691 views | 1 replies |
joemagda373194
Mac OS 10.6.4 Dreamweaver 4 10.0 Build 4117. I Go to use Form Builder for first time, activate... then go to insert, WA, then Insert Form... everything is fine until I go to "Choose a form"... let go of the Choose a form menu button, then there goes the spinning wheel. I've let it go for 10 minutes, then have to force quit Dreamweaver.
Need some help.
Have you tried deleting the cache file? If not this is the first thing you should do, here is a link to the instructions for this:
If this does not work then there might be a problem with the configuration folder. If this is the case you will need to rename or delete this folder to have it be recreated, here is a link to the steps that you can take for this:
showpost.php?p=12293&postcount=2
If you continue to have problems after trying these things please let me know and I will ensure that a free ticket is opened up for you.
