Can't get file upload to work
Thread began 8/10/2010 1:55 pm by Kev Hegan | Last modified 8/13/2010 4:35 pm by Jason Byrnes | 910 views | 5 replies |
Kev Hegan
I have used Data Assist to successfully create a searchable publications database for a client, with a little help from the forum, so I am very pleased to say I managed this with little knowledge of databases and mySQL thanks to your product :)
Now I have purchased Universal Email for the File Upload features because the client requires the ability to add files to their database.
So, I have copied the insert page and followed the instructions in "Adding Digital File Pro to Data Assist Insert and Update Pages". I found them pretty straightforward but unfortunately the resulting page doesn't seem to work. I have had to add two new fields to the database but I updated the recordset in the server behaviors so as far as I can tell the code looks ok. The page updates the fields it used to, but nothing is added to the new fields (RecordType and PresentedAt). I replaced the URL field (where previously a web address could be added) with the file upload stuff. I used the same ID as described in the documentation. Nothing is added to this field and no file is copied to the folder I specified.
It's probably a simple mistake, would someone have a quick look at my code and see if its obvious? I've attached a zipped version of the file.
I'm hoping that the filename will be added to the URL field. This is already set up to display as a link on my details page. Am I correct in thinking this is how it will work by default?
Thanks for any help you can give. I read with relief about the decision to carry on with forum support. We are doing everything on a tight budget and nearly $50 for a support ticket is out of the question.
journals_Insert_File.zip
to trouble shoot the issue, follow these steps:
1) Add the following code at line 1:
</php
error_reporting(E_ALL);
2) find the following line:
$WA_redirectURL = "journals_Results.php";
and change it to:
$WA_redirectURL = "";
On the bindings panel, expand the WA Global status group and drag the debug info binding to the body of the page.
report back the results after testing the upload again.
Kev Hegan
Hi Jason,
Thanks for your response. Here are the results with the debug code in the page:
Status object: WA_UploadResult1
statusCode : -1
errorMessage :
clientFileName :
fileExtension :
serverFileName :
serverSimpleFileName :
serverDirectory :
contentType :
fileWasOverwritten :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
is this from before or after trying to upload file? I would like to see the results from after trying to upload the file.
One issue i see is that the file you sent me is named "journals_Insert_File.php", but the forms action is set to post to "journals_Insert.php"
<form  action="journals_Insert.php" method="post" enctype="multipart/form-data" name="WADAInsertForm" id="WADAInsertForm">
try changing that to:
<form  action="journals_Insert_File.php" method="post" enctype="multipart/form-data" name="WADAInsertForm" id="WADAInsertForm">
Kev Hegan
Doh! I didn't think of that... I missed the obvious! Thanks so much, it seems to be working now :)
One remaining question:
The filename is entered in the database, but I have set up the file upload wizard to put the files in a 'files' folder. Is there an option to put a relative link (files/myfile.doc)? There are several options in the wizard but I'm not sure what they do (Field Name, Temp Path, Simple File Name and so on). I've found the getting started documentation, is there a detailed guide?
Thanks, Jason, your help is much appreciated.
in the insert record behavior, you can add "files/" in front of the code for the server file name binding:
files/<?php echo $WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]; ?>
